Community Member
Internal/External ring tones
we have a Call Manager cluster v4.1 and manage aprox 300 x 7912 and 7911 handsets at our remote sites. There is a slight difference between the ring tones of incoming calls from external and other internal extensions. I have been asked to make all the incoming call ring tones the same. is there a global setting within Call Manager to achieve this?
Darren.
Silver
Re: Internal/External ring tones
Edit the "RingList.xml" and "DistinctiveRingList.xml". Both files can be found in C:\Program Files\Cisco\TFTPPath. You need to have the desired rigntone in the DistictiveRingList.xml file.
Don't forget to restart the TFTP service.
MK
Hall of Fame Super Red
Hi Darren,
Just to add to the good info from MK (+5 MK :)
What you are seeing, or rather hearing is called :)
*Distinctive ring for on- and off-net status
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps556/ps6729/product_data_sheet0900aecd8042402c.html
This is "default" behaviour that cannot be changed by the Admin without changing the Gateway to On-Net.
Have a look at this thread, there is some good related info :)
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&topicID=.ee6c829&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cc2e750
Hope this helps!
Rob
142
