Internal hard drive testing on HP 7835
mgonzalez
I have a red light on the 2nd internal HD on my 7835H server running CallManager 5 and Linux OS. I know its gone bad and needs to be replaced but this is the 2nd drive in 2 months. I need to find a way to test/diagnose trouble on an internal HD. Since this is runnig Linux OS I'm assuming you can do this through SSH, but I don't know how. I tried looking in RTMT and I didn't see anything to status the HD. Any suggestions?
hadbou
Level 5
Level 5
The Cisco MCS 7845-H2 can run any of the following Cisco applications:
" Cisco Unified Communications Manager-Up to 7,500 Cisco Unified IP phones per server
" Cisco Emergency Responder-Up to 30,000 Cisco Unified IP phones per server
" Cisco Unified Presence
" Cisco Unified Intelligent Contact Management Enterprise
" Cisco Unified Intelligent Contact Management Hosted
" Cisco Unified Contact Center Enterprise
" Cisco Unified Contact Center Hosted
" Cisco Unified Contact Center Express
" Cisco IPICS
" Cisco Unified IP Interactive Voice Response (IVR)
" Cisco Unified Customer Voice Portal
" Cisco Unified MeetingPlace? conferencing
" Cisco Unified MeetingPlace Express
" Cisco Unified IP Queue Manager
" Cisco Unity? Unified Messaging
" Cisco Unity Connection
http://www.cisco.com/en/US/products/hw/voiceapp/ps378/prod_models_home.html
mhansen
Level 4
Level 4
could be bad controller giving you a red light due to a bug and not that the drive is bad...the SSH interface is very limited so you dont have access to typical linux debugging tools. If the server is under a support contract, suggest that the controller be replaced or the controller firmware upgraded to see if that helps.
Mike
gogasca
Level 10
Level 10
You can try show hardware or this SW:
HP Array Diagnostics Utility for
Linux.
http://tinyurl.com/tcaq7
