INTERNAL MOH IN CISCO CME
HI,
I HAVE CME VERSION 4.1 I NEED TO ACTIVET THE MOH IN INTERNAL CALLS, I UPLOAD THE FILE IN FLASH AND I DO THE CONFIGURATION BUT ITS NOT WORKING ITS JUST WORKING FROM PSTN CALLS.
IF ANY ONE HAVE THE CONFIGURATION PLS SEND IT TO ME.
REGARDE TO EVERYONE.
ALI NASSER
1 ACCEPTED SOLUTION
Re: INTERNAL MOH IN CISCO CME
Configuring Music on Hold from an Audio File
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/admin/configuration/guide/cmemoh.html#wp1010384
Review step 5
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Review step 5
java
java
This Link isn't available any more, so please can you post a Link with the same information on it?
thomas
Hall of Fame Super Gold
Just remove /partner from the link.
Note; usually internal callers will get annoyed soon to have to listen to music when a coworker places them on hold.
Thank you
Thank you for the nice rating and good luck!
998
