international call not going through
I am facing an issue of international call not going through and it is prompting sorry you are not authorized to call the number dialed.
I checked the CSS on the line and it is set to international CSS and in CDR i am seeing destination IP is populating as the GW IP.
The dial peer is configured to match 8011T and to route it to PRI. Below is the debug that was captured during call was made.
Calling Number=7806783806, Called Number=8011201000033573, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
049620: Nov 13 17:24:33: //-1/00648BED2700/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=1001
049621: Nov 13 17:24:33: //-1/00648BED2700/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
049622: Nov 13 17:24:33: //-1/00648BED2700/DPM/dpAssociateIncomingPeerCore:
049623: Nov 13 17:24:33: //-1/00648BED2700/DPM/dpAssociateIncomingPeerCore:
049624: Nov 13 17:24:33: //-1/00648BED2700/DPM/dpMatchSafModulePlugin:
049625: Nov 13 17:24:33: //-1/00648BED2700/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=XXXXXXXXX
   ----- ccCallInfo IE subfields -----
   cisco-ani=7806783806
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=8011201000033573
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
049626: Nov 13 17:24:33: //-1/00648BED2700/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x41240374, Call Info(
   Calling Number=7806783806,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=8011201000033573(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=1001, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=494
049627: Nov 13 17:24:33: //-1/00648BED2700/CCAPI/ccCheckClipClir:
   In: Calling Number=7806783806(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
049628: Nov 13 17:24:33: //-1/00648BED2700/CCAPI/ccCheckClipClir:
   Out: Calling Number=7806783806(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
049629: Nov 13 17:24:33: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
049630: Nov 13 17:24:33: :cc_get_feature_vsa malloc success
049631: Nov 13 17:24:33: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
049632: Nov 13 17:24:33:  cc_get_feature_vsa count is 1
049633: Nov 13 17:24:33: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
049634: Nov 13 17:24:33: :FEATURE_VSA attributes are: feature_name:0,feature_time:1013982736,feature_id:494
049635: Nov 13 17:24:33: //494/00648BED2700/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=7806783806(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=8011201000033573(TON=Unknown, NPI=Unknown))
049636: Nov 13 17:24:33: //494/00648BED2700/CCAPI/cc_process_call_setup_ind:
   Event=0x3D351600
049637: Nov 13 17:24:33: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 8011201000033573
049638: Nov 13 17:24:33: //494/00648BED2700/CCAPI/ccCallSetContext:
   Context=0x211903AC
049639: Nov 13 17:24:33: //494/00648BED2700/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 494 with tag 1001 to app "_ManagedAppProcess_Default"
049640: Nov 13 17:24:33: //494/00648BED2700/CCAPI/ccCallProceeding:
049641: Nov 13 17:24:33: //-1/00648BED2700/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=8011201000033573, Peer Info Type=DIALPEER_INFO_SPEECH
049642: Nov 13 17:24:33: //-1/00648BED2700/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=8011201000033573
049643: Nov 13 17:24:33: //-1/00648BED2700/DPM/dpMatchPeersCore:
   Result=Success(0) after DP_MATCH_DEST
049644: Nov 13 17:24:33: //-1/00648BED2700/DPM/dpMatchSafModulePlugin:
   dialstring=8011201000033573, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
049645: Nov 13 17:24:33: //-1/00648BED2700/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=4002
049646: Nov 13 17:24:33: //-1/00648BED2700/DPM/dpMatchPeersCore:
049647: Nov 13 17:24:33: //-1/00648BED2700/DPM/dpMatchPeersCore:
049648: Nov 13 17:24:33: //-1/00648BED2700/DPM/dpMatchPeersCore:
049649: Nov 13 17:24:33: //-1/00648BED2700/DPM/dpMatchSafModulePlugin:
049650: Nov 13 17:24:33: //-1/00648BED2700/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
049651: Nov 13 17:24:33: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=8011201000033573, Called Number=8011201000033573, Peer Info Type=DIALPEER_INFO_SPEECH
049652: Nov 13 17:24:33: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
049653: Nov 13 17:24:33: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
049654: Nov 13 17:24:33: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
049655: Nov 13 17:24:33: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
049656: Nov 13 17:24:33: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=8011201000033573, Called Number=, Voice-Interface=0x0,
049657: Nov 13 17:24:33: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=NO_MATCH(-1) After All Match Rules Attempt
049658: Nov 13 17:24:33: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
049659: Nov 13 17:24:33: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
049660: Nov 13 17:24:33: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
049661: Nov 13 17:24:33: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
049662: Nov 13 17:24:33: //-1/xxxxxxxxxxxx/CCAPI/cc_validate_mlpp_info:
   Unsupported MLPP Service Domain Network 0
049663: Nov 13 17:24:33: //-1/xxxxxxxxxxxx/CCAPI/cc_set_mlpp_info:
   Invalid MLPP Information
049664: Nov 13 17:24:33: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
049665: Nov 13 17:24:33: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
049666: Nov 13 17:24:33: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
049667: Nov 13 17:24:33: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
049668: Nov 13 17:24:33: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
049669: Nov 13 17:24:33: //-1/xxxxxxxxxxxx/CCAPI/cc_validate_mlpp_info:
049670: Nov 13 17:24:33: //-1/xxxxxxxxxxxx/CCAPI/cc_set_mlpp_info:
049671: Nov 13 17:24:33: //-1/xxxxxxxxxxxx/CCAPI/cc_validate_mlpp_info:
049672: Nov 13 17:24:33: //-1/xxxxxxxxxxxx/CCAPI/cc_set_mlpp_info:
049673: Nov 13 17:24:33: //-1/00648BED2700/DPM/dpMatchPeersCore:
049674: Nov 13 17:24:33: //-1/00648BED2700/DPM/dpMatchPeersCore:
049675: Nov 13 17:24:33: //-1/00648BED2700/DPM/dpMatchPeersCore:
049676: Nov 13 17:24:33: //-1/00648BED2700/DPM/dpMatchSafModulePlugin:
   dialstring=8011201000033573, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
049677: Nov 13 17:24:33: //-1/00648BED2700/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
049678: Nov 13 17:24:33: //494/00648BED2700/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=4002, Params=0x21197E9C, Progress Indication=NULL(0)
049679: Nov 13 17:24:33: //494/00648BED2700/CCAPI/ccCheckClipClir:
049680: Nov 13 17:24:33: //494/00648BED2700/CCAPI/ccCheckClipClir:
049681: Nov 13 17:24:33: //494/00648BED2700/CCAPI/ccCallSetupRequest:
   Destination Pattern=8011T, Called Number=8011201000033573, Digit Strip=TRUE
049682: Nov 13 17:24:33: //494/00648BED2700/CCAPI/ccCallSetupRequest:
   Redirect Number=, Display Info=
   Account Number=XXXXXXXX, Final Destination Flag=TRUE,
   Guid=00648BED-51E9-4146-2700-07110A09302B, Outgoing Dial-peer=4002
049683: Nov 13 17:24:33: //494/00648BED2700/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
049684: Nov 13 17:24:33: //494/00648BED2700/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x3D05E50C, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=7806783806,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=8011201000033573(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=4002, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
049685: Nov 13 17:24:33: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
049686: Nov 13 17:24:33: :cc_get_feature_vsa malloc success
049687: Nov 13 17:24:33: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
049688: Nov 13 17:24:33:  cc_get_feature_vsa count is 2
049689: Nov 13 17:24:33: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
049690: Nov 13 17:24:33: :FEATURE_VSA attributes are: feature_name:0,feature_time:1013982960,feature_id:495
049691: Nov 13 17:24:33: //495/00648BED2700/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
049692: Nov 13 17:24:33: //495/00648BED2700/CCAPI/ccCallSetContext:
   Context=0x21197E4C
049693: Nov 13 17:24:33: //494/00648BED2700/CCAPI/ccSaveDialpeerTag:
049694: Nov 13 17:24:33: ISDN Se0/1/0:23 Q931: Applying typeplan for sw-type 0x5 is 0x0 0x0, Calling num 7806783806
049695: Nov 13 17:24:33: ISDN Se0/1/0:23 Q931: Sending SETUP  callref = 0x00A5 callID = 0x8026 switch = primary-dms100 interface = User
049696: Nov 13 17:24:33: ISDN Se0/1/0:23 Q931: TX -> SETUP pd = 8  callref = 0x00A5
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98397
Exclusive, Channel 23
Calling Party Number i = 0x0081, '7806783806'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '011201000033573'
049697: Nov 13 17:24:34: ISDN Se0/1/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x80A5
049698: Nov 13 17:24:34: //495/00648BED2700/CCAPI/cc_api_call_proceeding:
   Interface=0x3D05E50C, Progress Indication=NULL(0)
049699: Nov 13 17:24:34: ISDN Se0/1/0:23 Q931: RX <- PROGRESS pd = 8  callref = 0x80A5
Progress Ind i = 0x8088 - In-band info or appropriate now available
049700: Nov 13 17:24:34: //495/00648BED2700/CCAPI/cc_api_call_cut_progress:
   Interface=0x3D05E50C, Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2),
   Cause Value=0
049701: Nov 13 17:24:34: //495/00648BED2700/CCAPI/cc_api_call_cut_progress:
   Call Entry(Responsed=TRUE)
049702: Nov 13 17:24:34: //494/00648BED2700/CCAPI/ccCallCutProgress:
   Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2), Cause Value=0
   Voice Call Send Alert=TRUE, Call Entry(Alert Sent=FALSE)
049703: Nov 13 17:24:34: //494/00648BED2700/CCAPI/ccCallCutProgress:
   Call CallAlert;
049704: Nov 13 17:24:34: //494/00648BED2700/CCAPI/ccCallAlert:
049705: Nov 13 17:24:34: //494/00648BED2700/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
049706: Nov 13 17:24:34: //495/00648BED2700/CCAPI/cc_api_get_called_ccm_detected:
   CallInfo(ccm detected=0)
049707: Nov 13 17:24:34: //494/00648BED2700/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID1=0x1EE, gcid=0-0-0-0, tag=0x0)
049708: Nov 13 17:24:34: //495/00648BED2700/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID2=0x1EF, gcid=0-0-0-0, tag=0x0)
049709: Nov 13 17:24:34: //494/00648BED2700/CCAPI/ccConferenceCreate:
   Conference Id=0xFFFFFFFF, Call Id1=494, Call Id2=495, Tag=0x0
049710: Nov 13 17:24:34: //494/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
049711: Nov 13 17:24:34: cc_api_get_xcode_stream : 4819
049712: Nov 13 17:24:34: //494/00648BED2700/CCAPI/cc_api_bridge_done:
   Conference Id=0x2E, Source Interface=0x41240374, Source Call Id=494,
   Destination Call Id=495, Disposition=0x0, Tag=0x0
049713: Nov 13 17:24:34: //495/00648BED2700/CCAPI/cc_api_bridge_done:
   Conference Id=0x2E, Source Interface=0x3D05E50C, Source Call Id=495,
   Destination Call Id=494, Disposition=0x0, Tag=0xFFFFFFFF
049714: Nov 13 17:24:34: //494/00648BED2700/CCAPI/cc_generic_bridge_done:
049715: Nov 13 17:24:34: //-1/xxxxxxxxxxxx/CCAPI/cc_exchange_calls_mlpp_info:
   Unable too Get MLPP nformation for callID 494
049716: Nov 13 17:24:34: //494/00648BED2700/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x2E, Destination Call Id=495)
049717: Nov 13 17:24:34: //495/00648BED2700/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x2E, Destination Call Id=494)
049718: Nov 13 17:24:34: //494/00648BED2700/CCAPI/ccConferenceCreate:
049719: Nov 13 17:24:34: confID:0x2E; callEntry1 callID1:0x1EE, type:1; callEntry2 callID2:0x1EF, type:6
049720: Nov 13 17:24:34: //495/00648BED2700/CCAPI/cc_api_caps_ind:
   Destination Interface=0x41240374, Destination Call Id=494, Source Call Id=495,
   Caps(Codec=0x1, Fax Rate=0x1, Fax Version:=0, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
049721: Nov 13 17:24:34: //495/00648BED2700/CCAPI/cc_api_caps_ind:
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
049722: Nov 13 17:24:34: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=7806783806, Peer Info Type=DIALPEER_INFO_SPEECH
049723: Nov 13 17:24:34: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=7806783806
049724: Nov 13 17:24:34: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
049725: Nov 13 17:24:34: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
049726: Nov 13 17:24:34: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
049727: Nov 13 17:24:34: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=011201000033573, Peer Info Type=DIALPEER_INFO_SPEECH
049728: Nov 13 17:24:34: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=011201000033573
049729: Nov 13 17:24:34: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
049730: Nov 13 17:24:34: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
049731: Nov 13 17:24:34: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
049732: Nov 13 17:24:34: //494/00648BED2700/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=494
049733: Nov 13 17:24:34: //495/00648BED2700/CCAPI/cc_api_get_called_ccm_detected:
049734: Nov 13 17:24:34: //494/00648BED2700/CCAPI/cc_api_get_delay_xport:
   CallInfo(delay xport=FALSE)
049735: Nov 13 17:24:34: //494/00648BED2700/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x2E, Call Id1=494, Call Id2=495
049736: Nov 13 17:24:34: //494/00648BED2700/CCAPI/cc_api_caps_ind:
   Destination Interface=0x3D05E50C, Destination Call Id=495, Source Call Id=494,
   Caps(Codec=0x1, Fax Rate=0x2, Fax Version:=0, Vad=0x1,
   Modem=0x2, Codec Bytes=160, Signal Type=2)
049737: Nov 13 17:24:34: //494/00648BED2700/CCAPI/cc_api_caps_ind:
049738: Nov 13 17:24:34: //494/00648BED2700/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Fax Version:=0, Vad=OFF(0x1),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=3205)
049739: Nov 13 17:24:34: //495/00648BED2700/CCAPI/cc_api_caps_ack:
att-camrosegosc1-vgw#
049740: Nov 13 17:24:34: //495/00648BED2700/CCAPI/cc_api_voice_mode_event:
   Call Id=495
049741: Nov 13 17:24:34: //495/00648BED2700/CCAPI/cc_api_voice_mode_event:
   Call Entry(Context=0x21197E4C)
049742: Nov 13 17:24:39: ISDN Se0/1/0:23 Q931: RX <- DISCONNECT pd = 8  callref = 0x80A5
Cause i = 0x8090 - Normal call clearing
049743: Nov 13 17:24:39: ISDN Se0/1/0:23 Q931: TX -> RELEASE pd = 8  callref = 0x00A5
049744: Nov 13 17:24:39: //495/00648BED2700/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x3D05E50C, Call Id=495
049745: Nov 13 17:24:39: //495/00648BED2700/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
049746: Nov 13 17:24:39: //494/00648BED2700/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
049747: Nov 13 17:24:39: //495/00648BED2700/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=495
049748: Nov 13 17:24:39: //494/00648BED2700/CCAPI/ccConferenceDestroy:
   Conference Id=0x2E, Tag=0x0
049749: Nov 13 17:24:39: //494/00648BED2700/CCAPI/ccConferenceDestroy:
049750: Nov 13 17:24:39: confID:0x2E; callEntry1 callID1:0x1EE, type:1; callEntry2 callID2:0x1EF, type:6
049751: Nov 13 17:24:39: //494/00648BED2700/CCAPI/cc_api_bridge_drop_done:
049752: Nov 13 17:24:39: //495/00648BED2700/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=494, Disposition=0x0, Tag=0x0
049753: Nov 13 17:24:39: //494/00648BED2700/CCAPI/cc_generic_bridge_done:
049754: Nov 13 17:24:39: //495/00648BED2700/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
049755: Nov 13 17:24:39: //495/00648BED2700/CCAPI/ccCallDisconnect:
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
049756: Nov 13 17:24:39: //495/00648BED2700/CCAPI/cc_api_get_transfer_info:
   Transfer Number=NULL
049757: Nov 13 17:24:39: ISDN Se0/1/0:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x80A5
049758: Nov 13 17:24:39: //495/00648BED2700/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3D05E50C, Tag=0x0, Call Id=495,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
049759: Nov 13 17:24:39: //495/00648BED2700/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
049760: Nov 13 17:24:39: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
049761: Nov 13 17:24:39: :cc_free_feature_vsa freeing 3C7026E8
049762: Nov 13 17:24:39: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
049763: Nov 13 17:24:39:  vsacount in free is 1
049764: Nov 13 17:24:39: //494/00648BED2700/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
049765: Nov 13 17:24:39: //494/00648BED2700/CCAPI/ccCallDisconnect:
049766: Nov 13 17:24:39: //494/00648BED2700/CCAPI/cc_api_get_transfer_info:
049767: Nov 13 17:24:39: //494/00648BED2700/CCAPI/cc_api_call_disconnect_done:
att-camrosegosc1-vgw#Disposition=0, Interface=0x41240374, Tag=0x0, Call Id=494,
049768: Nov 13 17:24:39: //494/00648BED2700/CCAPI/cc_api_call_disconnect_done:
049769: Nov 13 17:24:39: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
049770: Nov 13 17:24:39: :cc_free_feature_vsa freeing 3C702608
049771: Nov 13 17:24:39: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
049772: Nov 13 17:24:39:  vsacount in free is 0
049773: Nov 13 17:27:39: //-1/xxxxxxxxxxxx/CCAPI/ccAppShutdownMode:
   remove it from the queue
1 REPLY
I dont think this is in any
I dont think this is in any way related to your CSS settings as the outbound call is hitting your gateway and it is successfully able to set up the call, because you are seeing Q931.
looking at your debug info, your provider gives you a normal call clearing:
Take this up with your provider, and ask them to allow you to make international calls.
Please remember to rate useful posts, by clicking on the stars below.
42
