International Calling
I am trying to wrap my mind around NANP and the way it tags a call as being "international" "local" "long distance”.
I have an issue where my provider needs me to strip the 011 from a call if I am tagging the call as "international" when it is sent out of the gateway.
I thought I could create a RP with 4011. and strip the "pre dot" but the call manager then recatgorizes the call as "National" instead of "international".
Can someone explain how this is normally setup?
Should I strip the 011 at the GW (H323), if so how do I do this?
Cm 4.1.3sr5d
1 ACCEPTED SOLUTION
Re: International Calling
if you have the dial-peer pots just make the destination pattern 9011T all the exact matches will be dropped, you can also modify the plan on the GW
Voice Translation Rules
http://www.cisco.com/en/US/partner/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml
Number Translation using Voice Translation Profiles
http://www.cisco.com/en/US/customer/tech/tk652/tk90/technologies_configuration_example09186a00803f818a.shtml
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
1 REPLY
javalenc
java
106
