04-22-2008 11:06 AM - edited 03-15-2019 10:13 AM
Need to strip 4011 from an international call
Route pattern is 4.@ and I am using DDI "pre dot" I have captured a debug on my gateway and my called party number is 011XXXXXXXXXX my provider needs me to strip the 011 off of this call. Any ideas on the best way to do this?
H323 Gateway
CM 4.1.3
Solved! Go to Solution.
04-22-2008 11:13 AM
Try changing route pattern to 4011.@ and strip pre-dot and see if this gives the desired behavior.
Also, what do you international dial peers look like?
Hope that helped
04-22-2008 11:13 AM
Hope that helped
