09-24-2008 10:57 AM - edited 03-15-2019 01:31 PM
i have call manager 4.2(3)sr4 and international call fails, while other calls are going through.
when i use MGCP it is working fine but it doesnt work for h323.
09-24-2008 11:50 AM
What dial peer is being used for international calls. Can you turn on "debug voip dialpeer", make the call and post the output?
Brandon
09-24-2008 01:02 PM
Take a debug voice ccapi inout and paste the output, also upload the show run to check your configuration.
If you are using isdn you can take a debug isdn q931 and upload the results.
