International Dialing Fails with @ Route Pattern
UCM 7.1(5) to MGCP gateway.
Calls to International numbers using @ pattern fail. The provider is needs plan/type unknown, UCM is sending ISDN/International.
Any assistance is greatly appreciated.
Brian
Re: International Dialing Fails with @ Route Pattern
Try creating a 9.011! pattern.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Discreet patterns work but I need to maintain the @ route pattern if possible. Can the nanp file be edited like in CM4?
No, you cannot edit the NANP file.
java
java
217
