international dialing issue with ATT
I am running a CME at one remote location. The carrier is ATT and I am having issues with dialing internationally. When we debug the call we see the CME flags it as international and the digits its sending is 011 and then 011 <then the full number).
Att is stating we need to drop the 011 because they state we are sending it twice.
Can someone give me pointers on how to do this please?
Hall of Fame Super Gold
Re: international dialing issue with ATT
How is this currently configured on the router? The only way to send 011 twice, would be "no digit-strip" AND "prefix". Obviously, this doesn't work.
There are a couple of options, one is to dial as "unknown" type/plan with 011 as prefix. Possibly, even "international" type will work.
Another option is to drop prefix 011, and place call like an E.164 number.
All depends on how you have configured dial-peers and voice translation rules, and how ATT likes international calls to be placed. There may be more than one setting that work, too.
Currently this is the debug output:
Feb 26 18:41:40.516: ISDN Se0/3/0:23 Q931: Applying typeplan for sw-type 0xD is
0x2 0x1, Calling num 614XXXXXXX
Feb 26 18:41:40.520: ISDN Se0/3/0:23 Q931: Applying typeplan for sw-type 0xD is
0x1 0x1, Called num 011442074999000
Feb 26 18:41:40.520: ISDN Se0/3/0:23 Q921: User TX -> INFO sapi=0 tei=0, ns=15 n
r=42
Feb 26 18:41:40.520: ISDN Se0/3/0:23 Q931: SETUP pd = 8 callref = 0x0AD3
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98397
Exclusive, Channel 23
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x2180, '614XXXXXXX'
Plan:ISDN, Type:National
Called Party Number i = 0x91, '011442074999000'
Plan:ISDN, Type:International
Feb 26 18:41:40.536: ISDN Se0/3/0:23 Q921: User RX <- RR sapi=0 tei=0 nr=16
Feb 26 18:41:40.564: ISDN Se0/3/0:23 Q921: User RX <- INFO sapi=0 tei=0, ns=42 n
r=16
Feb 26 18:41:40.564: ISDN Se0/3/0:23 Q931: CALL_PROC pd = 8 callref = 0x8AD3
Feb 26 18:41:40.568: ISDN Se0/3/0:23 Q921: User TX -> RR sapi=0 tei=0 nr=43
Feb 26 18:41:40.568: ISDN Se0/3/0:23 Q921: User RX <- INFO sapi=0 tei=0, ns=43 n
r=16
Feb 26 18:41:40.568: ISDN Se0/3/0:23 Q931: PROGRESS pd = 8 callref = 0x8AD3
Cause i = 0x829F - Normal, unspecified
Progress Ind i = 0x8488 - In-band info or appropriate now available
Feb 26 18:41:40.568: ISDN Se0/3/0:23 Q921: User TX -> RR sapi=0 tei=0 nr=44
we are sending 011442074999000 along with Plan:ISDN, Type:International.
Now ATT wants us to drop the 011 but still send the ISDN international plan.
How do I go abouts doing it. I created
dial-peer voice 105 pots
description International
preference 1
destination-pattern 9011T
direct-inward-dial
port 0/3/0:23
forward-digits 12
but it will forward 442074999000 but the isdn plan is now unknown.
is there a easy way to correct this?
Gold
remove the forward digits command and that solve the problem with 011 being sent to the telco. Also, add the command
isdn map address ^011* plan ISDN type International
When I did that it sends no digits.
The easier way would be "numbering-type international" under dial-peer 105.
There are more ways ... :)
Also, probably you want "forward-digits all"
Please rate useful posts.
so if I add that it would look like
preference 1
direct-inward-dial
port 0/3/0:23
forward-digits 12
this should work where it will send the 44* and international type?
Gold
When you changed the forward-digits, Did you use the option "default forward-digits" or "no forward-digits". Note that if you use the 2nd option, the configuration would show "forward-digits 0", which means do not forward digits. You need to use "default forward-digits" with the above config instead of "forward-digits 12"
I did the default
Yes. In my post above, I was already saying that what telco likes is E.164 format with international type (you can think about international as being the + in E.164).
Note that unless you have multiple dial-peers to same destination, preference is not needed.
I did an install of CME in Texas, and had a similiar problem, and i think the config below fixed the issue.
(8 is used to access the pstn)
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn incoming-voice voice
isdn map address 011* plan unknown type unknown
no cdp enable
dial-peer voice 12 pots
translation-profile outgoing OutBound
destination-pattern 8011T
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
incoming called-number .
direct-inward-dial
port 0/0/1:23
prefix 011
Cheers
Tony
597
