Bronze
International Dialing
I don't know what happend since this afternoon our international calls are not going out. Here's the output of debug ccapi:
Nov 13 01:15:03.439 EST: //-1/0013D7580302/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=Darlene Dwyer
   ----- ccCallInfo IE subfields -----
   cisco-ani=55557
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=90113491310711
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Nov 13 01:15:03.439 EST: //-1/0013D7580302/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x70A5CE0C, Call Info(
   Calling Number=55557,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=90113491310711(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=10220011, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=2003
Nov 13 01:15:03.439 EST: //-1/0013D7580302/CCAPI/ccCheckClipClir:
   In: Calling Number=55557(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
   Out: Calling Number=55557(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Nov 13 01:15:03.439 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Nov 13 01:15:03.439 EST: :cc_get_feature_vsa malloc success
Nov 13 01:15:03.439 EST:  cc_get_feature_vsa count is 1
Nov 13 01:15:03.439 EST: :FEATURE_VSA attributes are: feature_name:0,feature_time:1971458984,feature_id:2003
Nov 13 01:15:03.439 EST: //2003/0013D7580302/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=55557(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=90113491310711(TON=Unknown, NPI=Unknown))
Nov 13 01:15:03.439 EST: //2003/0013D7580302/CCAPI/cc_process_call_setup_ind:
   Event=0x70F9CEF8
Nov 13 01:15:03.439 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 90113491310711
Nov 13 01:15:03.439 EST: //2003/0013D7580302/CCAPI/ccCallSetContext:
   Context=0x756F12B8
   >>>>CCAPI handed cid 2003 with tag 10220011 to app "_ManagedAppProcess_Default"
Nov 13 01:15:03.439 EST: //2003/0013D7580302/CCAPI/ccCallProceeding:
Nov 13 01:15:03.439 EST: //2003/0013D7580302/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=1050, Params=0x756F21F8, Progress Indication=NULL(0)
Nov 13 01:15:03.439 EST: //2003/0013D7580302/CCAPI/cc_fill_tg_params:
   Not a cic call
   Trunk Group Select Interface Success;
   Interface=0x692FE574, Selected Interface=1, Selected DSL=1
Nov 13 01:15:03.443 EST: //2003/0013D7580302/CCAPI/ccCheckClipClir:
Nov 13 01:15:03.443 EST: //2003/0013D7580302/CCAPI/ccCallSetupRequest:
   Destination Pattern=9011T, Called Number=90113491310711, Digit Strip=TRUE
   Redirect Number=, Display Info=Darlene Dwyer
   Account Number=Darlene Dwyer, Final Destination Flag=TRUE,
   Guid=0013D758-E72C-E1CD-0302-4A020A14293A, Outgoing Dial-peer=1050
Nov 13 01:15:03.443 EST: //2003/0013D7580302/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=55557
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=90113491310711
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Nov 13 01:15:03.443 EST: //2003/0013D7580302/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x692FE574, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=55557,(Calling Name=Darlene Dwyer)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=90113491310711(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=1050, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=PRILD, tg_label_flag=2, Application Call Id=)
Nov 13 01:15:03.443 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Nov 13 01:15:03.443 EST: :cc_get_feature_vsa malloc success
Nov 13 01:15:03.443 EST:  cc_get_feature_vsa count is 2
Nov 13 01:15:03.443 EST: :FEATURE_VSA attributes are: feature_name:0,feature_time:1971458760,feature_id:2004
Nov 13 01:15:03.443 EST: //2004/0013D7580302/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
   Trunk Group Call Setting;
   Call Entry(Retry Count=0, Voice Class Cause Code=0)
rtprtr03#
Nov 13 01:15:03.443 EST: //2004/0013D7580302/CCAPI/ccCallSetContext:
   Context=0x756F21A8
Nov 13 01:15:03.443 EST: //2003/0013D7580302/CCAPI/ccSaveDialpeerTag:
Nov 13 01:15:03.443 EST: //2003/0013D7580302/CCAPI/cc_api_modify_tgt_cid_call_active_record:
   Target Trkgrp Route Label=PRILD, tg_label_flag=TRUE, Call Id=0x7D3
Nov 13 01:15:03.523 EST: //2004/0013D7580302/CCAPI/cc_api_call_proceeding:
   Interface=0x692FE574, Progress Indication=NULL(0)
rtprtr03#
Nov 13 01:15:04.899 EST: //2004/0013D7580302/CCAPI/cc_api_call_cut_progress:
   Interface=0x692FE574, Progress Indication=NOT END TO END ISDN(1), Signal Indication=INTERCEPT(2),
   Cause Value=28
   Call Entry(Responsed=TRUE)
Nov 13 01:15:04.899 EST: //2003/0013D7580302/CCAPI/ccCallCutProgress:
   Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2), Cause Value=28
   Voice Call Send Alert=TRUE, Call Entry(Alert Sent=FALSE)
   Call CallAlert;
Nov 13 01:15:04.899 EST: //2003/0013D7580302/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Nov 13 01:15:04.899 EST: //2004/0013D7580302/CCAPI/cc_api_get_called_ccm_detected:
   CallInfo(ccm detected=0)
Nov 13 01:15:04.903 EST: //2003/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x751ED254, callID1=0x7D3, callID2=0x7D4, tag=0x0)
   (confID=0x751ED254, callID1=0x7D3, gcid=0-0-0-0, tag=0x0)
Nov 13 01:15:04.903 EST: //2004/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x751ED254, callID2=0x7D4, gcid=0-0-0-0, tag=0x0)
Nov 13 01:15:04.903 EST: //2003/0013D7580302/CCAPI/ccConferenceCreate:
   Conference Id=0x751ED254, Call Id1=2003, Call Id2=2004, Tag=0x0
Nov 13 01:15:04.903 EST: //2003/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Nov 13 01:15:04.903 EST: cc_api_get_xcode_stream : 4510
Nov 13 01:15:04.903 EST: //2003/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x26F, Source Interface=0x70A5CE0C, Source Call Id=2003,
   Destination Call Id=2004, Disposition=0x0, Tag=0x0
Nov 13 01:15:04.903 EST: //2004/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x26F, Source Interface=0x692FE574, Source Call Id=2004,
   Destination Call Id=2003, Disposition=0x0, Tag=0xFFFFFFFF
Nov 13 01:15:04.903 EST: //2003/0013D7580302/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x26F, Destination Call Id=2004)
Nov 13 01:15:04.903 EST: //2004/0013D7580302/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x26F, Destination Call Id=2003)
Nov 13 01:15:04.903 EST: //2004/0013D7580302/CCAPI/cc_api_caps_ind:
   Destination Interface=0x70A5CE0C, Destination Call Id=2003, Source Call Id=2004,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
Nov 13 01:15:04.903 EST: //2003/0013D7580302/CCAPI/cc_api_get_delay_xport:
   CallInfo(delay xport=FALSE)
Nov 13 01:15:04.903 EST: //2003/0013D7580302/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x26F, Call Id1=2003, Call Id2=2004
Nov 13 01:15:04.903 EST: //2003/0013D7580302/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=2003
Nov 13 01:15:04.903 EST: //2004/0013D7580302/CCAPI/cc_api_get_called_ccm_detected:
Nov 13 01:15:04.919 EST: //2003/0013D7580302/CCAPI/cc_api_caps_ind:
   Destination Interface=0x692FE574, Destination Call Id=2004, Source Call Id=2003,
   Caps(Codec=0x1, Fax Rate=0x80, Vad=0x1,
   Modem=0x2, Codec Bytes=160, Signal Type=2)
Nov 13 01:15:04.919 EST: //2003/0013D7580302/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_14400(0x80), Vad=OFF(0x1),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=5587)
Nov 13 01:15:04.919 EST: //2004/0013D7580302/CCAPI/cc_api_caps_ack:
Nov 13 01:15:04.919 EST: //2004/0013D7580302/CCAPI/cc_api_voice_mode_event:
   Call Id=2004
rtprtr03#
   Call Entry(Context=0x756F21A8)
rtprtr03#
Nov 13 01:15:07.663 EST: //2003/0013D7580302/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x70A5CE0C, Call Id=2003
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Nov 13 01:15:07.663 EST: //2003/0013D7580302/CCAPI/ccConferenceDestroy:
   Conference Id=0x26F, Tag=0x0
Nov 13 01:15:07.663 EST: //2003/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Nov 13 01:15:07.663 EST: //2004/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=2003, Disposition=0x0, Tag=0x0
Nov 13 01:15:07.663 EST: //2003/0013D7580302/CCAPI/cc_generic_bridge_done:
Nov 13 01:15:07.663 EST: //2004/0013D7580302/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
rtprtr03#
Nov 13 01:15:07.663 EST: //2004/0013D7580302/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Nov 13 01:15:07.667 EST: //2003/0013D7580302/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Nov 13 01:15:07.667 EST: //2003/0013D7580302/CCAPI/cc_api_get_transfer_info:
Nov 13 01:15:07.715 EST: //2004/0013D7580302/CCAPI/cc_api_call_disconnect_done:
rtprtr03#
rtprtr03#Disposition=0, Interface=0x692FE574, Tag=0x0, Call Id=2004,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   tg for this call is PRILD success/fail is 1
   Call Disconnect Event Sent
Nov 13 01:15:07.715 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Nov 13 01:15:07.715 EST: :cc_free_feature_vsa freeing 758212C0
Nov 13 01:15:07.715 EST:  vsacount in free is 1
rtprtr03#
Nov 13 01:15:10.667 EST: //2003/0013D7580302/CCAPI/cc_api_get_transfer_info:
Nov 13 01:15:10.667 EST: //2003/0013D7580302/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x70A5CE0C, Tag=0x0, Call Id=2003,
Nov 13 01:15:10.667 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Nov 13 01:15:10.667 EST: :cc_free_feature_vsa freeing 758213A0
and here's the config of the dial it is hitting:
dial-peer voice 1050 pots
trunkgroup PRILD
description International Outbound LD Circuit
destination-pattern 9011T
progress_ind progress enable 8
progress_ind connect enable 8
prefix 011
Re: International Dialing
The trace shows the call is being disconnected normally (cause 16)
Is there any chance you can post the output of debug isdn q931?
Also do calls to non-international destinations work? - if yes can you post debugs and the relevent dial-peer config
Bronze
The message is "Your international call can not be completed as is dialed. The non internatinal calls work.  Here's the output of debut isdn q931.
Nov 13 09:21:58.865 EST: ISDN Se0/2/0:23 Q931: TX -> SETUP pd = 8  callref = 0x0201
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Display i = 'GUEST PHONE - 31008'
        Calling Party Number i = 0x0181, '9199931008'
                Plan:ISDN, Type:Unknown
        Called Party Number i = 0x81, '011982122256563'
Nov 13 09:21:58.957 EST: ISDN Se0/2/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x8201
rtprtr03#
Nov 13 09:22:10.397 EST: ISDN Se0/2/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x0201
        Cause i = 0x8090 - Normal call clearing
Nov 13 09:22:10.425 EST: ISDN Se0/2/0:23 Q931: RX <- RELEASE pd = 8  callref = 0x8201
Nov 13 09:22:10.425 EST: ISDN Se0/2/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x0201
rtprtr03#
Nov 13 09:22:24.237 EST: ISDN Se0/2/0:23 Q931: pak_private_number: Invalid type/plan 0x0 0x0 may be overriden; sw-type 13
Nov 13 09:22:24.237 EST: ISDN Se0/2/0:23 Q931: Applying typeplan for sw-type 0xD is 0x0 0x1, Calling num 9199931008
Nov 13 09:22:24.237 EST: ISDN Se0/2/0:23 Q931: Sending SETUP  callref = 0x0202 callID = 0x8215 switch = primary-ni interface = User
rtprtr03#
Nov 13 09:22:24.237 EST: ISDN Se0/2/0:23 Q931: TX -> SETUP pd = 8  callref = 0x0202
                Standard = CCITT
        Called Party Number i = 0x81, '01198212225536'
Nov 13 09:22:24.309 EST: ISDN Se0/2/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x8202
rtprtr03#
Nov 13 09:22:25.201 EST: ISDN Se0/2/0:23 Q931: RX <- PROGRESS pd = 8  callref = 0x8202
        Cause i = 0x8781 - Unallocated/unassigned number
        Progress Ind i = 0x8A81 - Call not end-to-end ISDN, may have in-band info
rtprtr03#
Nov 13 09:22:33.213 EST: ISDN Se0/2/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x0202
Nov 13 09:22:33.253 EST: ISDN Se0/2/0:23 Q931: RX <- RELEASE pd = 8  callref = 0x8202
Nov 13 09:22:33.257 EST: ISDN Se0/2/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x0202
VIP Super Bronze
It appears the provider suddenly wants you to set the ISDN numbering plan and type. Try adding this and then typing translation-profile outgoing PSTN_Trunk_Outgoing on your dial-peer:
voice translation-rule 1
rule 1 /^9011.*/ /\0/ type any international plan any isdn
rule 2 /^9[2-9]..[2-9]......$/ /\0/ type any subscriber plan any isdn
rule 3 /^9[2-9]......$/ /\0/ type any subscriber plan any isdn
rule 4 /^91[2-9]..[2-9]......$/ /\0/ type any national plan any isdn
voice translation-profile PSTN_Trunk_Outgoing
translate called 1
If this still doesn't fix it, it is also possible the provider does not want to see the 011 prefix when the TON value is set; try adjusting your dial-peer to remove that. If none of this fixes it, call your provider. Heck call them anyways and complain they changed the circuit configuration.
Bronze
Thanks Jonathan, it worked :-)
655
