International escape character "+"
carlosjlopez
Hi all,
I know that we can use a plus sign preceded by a backslash, that is, \+, for indicate the using of the international escape character in CUCM 7.
is there any way to use that with CCM 4.2?
Thanks in advance
Jaime Valencia
the + capability in CUCM is introduced in 7.X, no previous version had this
java
if this helps, please rate
java
thanks javalenc for your fast answer.
do you know if it's possible than Cisco offer an update for previous version of CCM?
no, this will only be on 7.X and onwards
java
java
