international not blocking
zeuscyril
Level 4
Level 4
hi friends
i am using the following commands to block 00 in ccme
after-hours block pattern 1 900 7-24
after-hours day Sun 00:00 23:59
after-hours day Mon 00:00 23:59
after-hours day Tue 00:00 23:59
after-hours day Wed 00:00 23:59
after-hours day Thu 00:00 23:59
after-hours day Fri 00:00 23:59
after-hours day Sat 00:00 23:59
and i am using pin for some extension to call isd.
but my problem is all the extensions are able to call ISD without pin
Brandon Buffin
What version of CME? What type of phones? Prior to CME 3.4, call blocking would only work for IP phones and analog phones attached to SCCP-controlled ATA or FXS ports.
Hope this helps.
Brandon
my ios version Version 12.4(1r).
ip phones are 7960&7912
but the blocking was working before.
i removed voicemail from all the users
and i changed the pin for international calls .
after that only the problem started.
Try this config:
login timeout 5 clear 18:00
after-hours day Sun 00:01 23:59
after-hours day Mon 00:01 23:59
after-hours day Tue 00:01 23:59
after-hours day Wed 00:01 23:59
after-hours day Thu 00:01 23:59
after-hours day Fri 00:01 23:59
after-hours day Sat 00:01 23:59
Also, make sure the Phone is not exempt. Otherwise it wont ask user for PIN and will allow calls.
