Internet Explorer Add-on for Call Manager
Is there an Internet Explorer Add-on for Call Manager? I would like to install something similiar to Skype that would recongnize phone number's that you can click on and it will call using the Cisco IP Phone.
1 ACCEPTED SOLUTION
Re: Internet Explorer Add-on for Call Manager
Cisco Unified Communications Widgets - Click to Call At-A-Glance
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6882/ps9156/at_a_glance_c45-487474.pdf
Release Note for Click to Call Release 7.x
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cupa/click_to_call/7.0/english/release/ReleaseNote_c2c.html
There's a lot more info if you want more reference or reading material, just search click to call on CCO.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
1 REPLY
java
java
561
