03-13-2008 05:50 AM - edited 03-15-2019 09:25 AM
We have 2 offices with each a CallManager Express + Cisco Unity Express setup.
One office is using 24... for extensions and the other office is using 37...
We have a dial-peer in place which allows both offices to call each others. This works very well.
However, I would like to be able to do the same thing from the auto-attendant. When someone calls 555-555-1234, which would be our office phone number, I'd like this person to be able to dial an extension number from the remote office, vice-versa.
Is this possible ? If so... how ?
Thanks !
03-13-2008 07:21 AM
Have you tried with CUE AA ?
If you have problems with that, try B-ACD/AA that should work. Remember to set maximu digits for dial by extension else you can be subject to too fraud:
http://cisco.com/en/US/docs/voice_ip_comm/cucme/bacd/configuration/guide/40bacd.html
You can also have both CUE's AA and B-ACD/AA, that is useful in some cases:
03-13-2008 07:30 AM
Hi!
Well, actually, it works, which I guess mean the AA is correct...?
To make it works, I have to do the following:
username test.one create
username test.one phonenumber "37999"
So I don't receive an "unknown extension" when I dial the number through the Auto Attendant.
Is this a normal behavior ? Is there a way to automatically forward extensions starting with 37... to the other router, or I'll need to add every remote extensions in my local Cisco Unity Express?
Thanks again.
03-13-2008 08:16 AM
Yes I believe you need to create all the users but that is not necessarily bad as they would need to be created for voicemail anyway.
Using B-ACD/AA dial-by-extnesion, there's no need to created users individually.
03-13-2008 08:43 AM
We have Cisco Unity Express in every offices, so we don't need voice mailbox for every users on one CUE.
I'll check this B-ACD thing. Thanks.
