Intiate a Test Call from Cisco 3945 Router
I was able to intiate test call from Cisco 3845 Routers using command "csim start <number> ". Now in the new Cisco 3945 Router the same command is not working. Could someone help me on this.
Aby Laurance Cherian
  • IP Telephony
Hall of Fame Super Gold
Re: Intiate a Test Call from Cisco 3945 Router
Csim is an undocumented and unsupported command, consequenly Cisco is free to change or remove it without warning.
If they have removed that command then BOOOOOOOOOOOOOOOOOOOOOOOOO!!!!!!!!
If they remove the write command like they have been threatening to do for some time now then DOUBLE BOOOOOOOOOOO!!
It doesn't seem to have been removed, just broken.
if you are on the 3945 via ssh it doesnt work ?
Telnet. The SSH idiosyncracy is well known.
I am using telnet to login to cisco 3945 Router. Could anyone confirm whether this command is functional in Cisco 3945?
As indicated above.
Hi Paolo,
Is there any alternate command for test call. Thanks in advance.
Not that I know.
3296
