intra-cluster communicatoin is broken after changing IP address of CCM6.1
rayon.man
I follow the procedure to change IP address in CallManager Cluster
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/6_1_2/ipchange/ipchg612.pdf
After I changed it, I run the command "utils diagnose module validate_network" and get the following error:
Error, intra-cluster communication is broken, unable to connect to [X.X.X.X]
How can I fix this problem? thanks!
Marwan ALshawi
i would suggest u to delet the ICT u have and rebuilt it again after u changed the IPs
intra-cluster communication is broken. Not Inter-cluster
Anyone have idea to fix it?
Did you ever resolve this issue? I'm having the same problem.
Sean
nelsonjuarez
i have the same problem , but in cisco mediasense 8.5.4
