Hall of Fame Super Gold
Introducing broadcast hunt-group service for CME
Due to popular demand I wrote this script for the purpose of ringing simultaneously more than one ephone without using shared lines. Like the broadcast hunt-group available for SIP phones, or in CCM.
I haven't tested it completely, currently it works only when all the destinations are SCCP phones, although the objective is to allow mix and match of SCCP phones, SIP phones, pots DPs, etc.
The script can now be acquired at ciscoscripts.com
Community Member
Re: Introducing broadcast hunt-group service for CME
HI Paolo
I'm attempting to take advantage of your broadcast script you have produced. I'm having a few problems not getting the calls to broadcast. At the moment I'm just playing around with it on a standalone CME with 4 stand 7941 phones. I have used the following config and also shown the output:
application
service bcast flash:bcast.tcl
Jan 4 10:45:47.139: //-1//HIFS:/hifs_ifs_cb: hifs ifs file read succeeded. size=5571, url=flash:bcast.tcl
Jan 4 10:45:47.139: //-1//HIFS:/hifs_free_idata: hifs_free_idata: 0x457E9518
Jan 4 10:45:47.139: //-1//HIFS:/hifs_hold_idata: hifs_hold_idata: 0x457E9518
param destinations 201,202
Warning: parameter destinations has not been registered under bcast namespace
I have then used:
dial-peer voice 100 pots
description broadcast hunt-group
service bcast
incoming called-number 555
failing call flow:
7941(1) - > 555 -> CME-> Broadcast (phone2,Phone3)
When I try to dial 555 from one of the phones it just comes up with number unknown and fails to broadcast. I am also running with cme 3.3 but can upgrade if needed. Also I have no analogue lines just pure VOIP at the moment. I think its some thing to do with the dial-peer?
Bronze
Thanks Paolo the problem was with the loopback dial peer. I wasnt using a loopback address:(. It now seems to work pretty well, Thanks.
You welcome Matthew. Please remember to rate useful posts using the scrollbox below!
Community Member
Hello, I want to test this script as well I was wondering what you ment by a loopback dial peer? Thanks.
Because tcl/ivr scripts can be activated on incoming DPs only, if you want the service to be accessible from internal phones, you need the call to go out via voip and come back into the router, that is a loopback DP.
If you don't need that, a pots incoming DP is enough.
Community Member
can you give me an example config of a loopback DP? Thanks!
Download any of the scripts that I wrote and there are examples in it.
Community Member
Paolo,
I've done quite a bit of testing with this script in my lab...thank you very much for this script.
I'm interested in hearing if you have any ideas on how to handle ring no answer. That is, provide an extension to transfer to (voicemail) if no one answers the phone.
Also, can you forsee a way to extend the amount of time the hunt occurs?
Thanks again!
Community Member
Hi Paolo
The tcl script is not available you provided.  Can you please upload it again.
749
