Invalid Number, Telco delayed message
I use a PRI T1 with SIP Voice Gateway. Whenever i dial an invalid number, the message from telco saying this is invalid is received after 100sec. Is there any way to reduce the time the Telco message is played.
if the delay is from telco, better to have a word with them to reduce this delay.
Please rate all the useful posts
//Suresh Please rate all the useful posts.
The customer recently moved from Nortel to Cisco, Telco message was faster on a Nortel box
Hi Madusudan,
You can check with Telco the timer or parameter in signaling based on which they decide when to play the Invalid number announcement. Once it is known you can check whether it can be tweaked on your Cisco box through a service parameter or some other setting.
Manish
