IOS 15 w/ pvdm3 conference
What is the difference between the commands "maximum conference participants" , and "maximum sessions", when configuring hardware based CFB's on IOS 15 with pvdm3 modules?
thanks
Re: IOS 15 w/ pvdm3 conference
maximum conference participants = how many conferencees you can have in the same conference. This is completely codec dependant.
maximum sessions = how many simultaneous conferences you can have on that HW
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Yes, this helps.  What is the default for maximum conference participants?  When the ? is used after the command, it states what type of codec is being used, and what values can also be used., in this case G729  How is that determined, as its not the first choice in the profile.
A DSP can be configured to support either conferencing, transcoding or MTP sessions, whether the
number of participants refers to the number of conferees supported on a conference. For example, you can
have 8 sessions, with 64 participants each. This will depend on the number of DSPs you have available, on
the type of platform, voice interface, etc.
Refer to:
http://www.cisco.com/en/US/partner/docs/ios/12_3/vvf_c/interop/intcnf2.html#wp1042189
and
http://www.cisco.com/en/US/partner/docs/routers/access/1900/software/configuration/guide/pvdm3_config_ps10538_TSD_Products_Configuration_Guide_Chapter.html
Tere.
Regards, Tere. If you find this post helpful, please rate! :)
maximum conference-participants
To configure the maximum number of conference participants allowed in  each meet-me conference, use the maximum  conference-participants command in DSP farm profile configuration  mode. To reset the maximum to the default number, use the no form of this command.
maximum conference-participants max-participants
no maximum conference-participants max-participants
Syntax Description
max-participants
Maximum number of participants allowed in each meet-me conference  session. One DSP can support the following maximums:
G.711—32 participants
G.729—16 participants
The default is 8 participants.
Command Default
The default maximum number of participants is 8.
Above from command reference tool for IOS (15.1M&T)
It still needs to be updates in order to show the new PVDM3s capabilities, but you can get an idea of how this works.
If you enable more than 1 codec per profile then the maximum is defined by the highest complexity codec.
The ideal use for this command is when you enable just 1 codec per profile.
java
java
1024
