Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
IOS and CCME upgrade
I have a new 3825 router and has IOS Version 12.4(13r)T and CCME 3.3
I want to upgrade to CCME 4.1 and the last IOS version.
How can I do it? Is it possible to do it by the USB ports ?
1 REPLY
Hall of Fame Super Gold
Re: IOS and CCME upgrade
Hola sarenos,
The IOS you indicate does not exist, more likely you have 12.4(3). Upgrade with USB is perfectly possible, just copy the IOS image onto the stick from another router or PC. If you use GUI copy that as well.
Hope this helps, if so please rate post!
108
