Bronze
IOS Conference Bridge will not register on CM7.0(1)
I have created a H/W conference bridge called HOHWCFB on CM7.0(1) and have configured a 2821 to register to it.
Type of bridge selected was IOS Enhanced.
Running IOS c2800nm-spservicesk9-mz.124-20.T1.bin
The status on CM7.0(1) is 'unknown'. Not even rejected.
No hint of it registering. Reset many times.
I have reloaded both gwy and CM.
Here is my 2821 gwy config for sccp:
fdp2821gwy#shr sccp
sccp local GigabitEthernet0/1
sccp ccm 10.100.103.11 identifier 1 version 6.0
sccp ip precedence 3
sccp
sccp ccm group 103
bind interface GigabitEthernet0/1
associate profile 20 register HOHWCFB
associate profile 10 register HOXCODE
keepalive retries 5
dspfarm profile 10 transcode
description **HW Transcoder
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
maximum sessions 2
associate application SCCP
shutdown
dspfarm profile 20 conference
description **HW ConferenceBridge
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 4
fdp2821gwy#sh sccp all
SCCP Admin State: UP
Gateway IP Address: 10.100.103.101, Port Number: 2000
IP Precedence: 3
User Masked Codec list: None
Call Manager: 10.100.103.11, Port Number: 2000
Priority: N/A, Version: 6.0, Identifier: 1
Trustpoint: N/A
Conferencing Oper State: ACTIVE_IN_PROGRESS - Cause Code: SOCKET_OPEN_FAILED
Active Call Manager: NONE
TCP Link Status: NOT_CONNECTED, Profile Identifier: 20
Reported Max Streams: 32, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: g729ar8, Maximum Packetization Period: 60
Supported Codec: g729abr8, Maximum Packetization Period: 60
Supported Codec: g729r8, Maximum Packetization Period: 60
Supported Codec: g729br8, Maximum Packetization Period: 60
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period: 30
SCCP Application Service(s) Statistics:
Profile Identifier: 20, Service Type: Conferencing
TCP packets rx 0, tx 0
Unsupported pkts rx 0, Unrecognized pkts rx 0
Register tx 0, successful 0, rejected 0, failed 0
KeepAlive tx 0, successful 0, failed 0
OpenReceiveChannel rx 0, successful 0, failed 0
CloseReceiveChannel rx 0, successful 0, failed 0
StartMediaTransmission rx 0, successful 0, failed 0
StopMediaTransmission rx 0, successful 0, failed 0
PortReq rx 0
PortRes tx 0, successful 0, failed 0
PortClose rx 0
QosListen rx 0
QosPath rx 0
QosTeardown rx 0, send 0, recv 0, sendrecv 0
QosResvNotify tx 0, send 0, recv 0, sendrecv 0
QosErrorNotify tx 0, send 0, recv 0, sendrecv 0
err0 0, err1 0, err2 0, err3 0, err4 0, err5 0,
err6 0, err7 0, err8 0, err9 0, err10 0, err11 0,
err12 0
QosModify rx 0, send 0, recv 0, sendrecv 0
UpdateDscp rx 0
Reset rx 0, successful 0, failed 0
MediaStreamingFailure rx 0
MediaStreamingFailure tx 0
Switchover 0, Switchback 0
CCM Group Identifier: 103
Description: None
Binded Interface: GigabitEthernet0/1, IP Address: 10.100.103.101
Associated Profile: 20, Registration Name: HOHWCFB
Associated Profile: 10, Registration Name: HOXCODE
Registration Retries: 3, Registration Timeout: 10 sec
Keepalive Retries: 5, Keepalive Timeout: 30 sec
CCM Connect Retries: 3, CCM Connect Interval: 10 sec
Switchover Method: GRACEFUL, Switchback Method: GRACEFUL_GUARD
Switchback Interval: 10 sec, Switchback Timeout: 7200 sec
Signaling DSCP value: cs3, Audio DSCP value: ef
fdp2821gwy#
Re: IOS Conference Bridge will not register on CM7.0(1)
try taking out the version from this command:
do a no sccp / sccp and reset from CUCM
java
if this helps, please rate
java
www.cisco.com/go/pdi
You're missing the ccm association.
sccp ccm group 103
associate ccm 1 priority 1
exit
no sccp
sccp
hth,
nick
Bronze
Bingo!
Nick got it.
I guess I just couldn't see the wood for the trees. I was staring and staring, and I think I actually removed that command to change the IP address (correct it) of the CM and then forgot to reapply it. Many, many tx Nick!
This is a working config!
fdp2821gwy#shr sccp
sccp
sccp ccm group 103
keepalive retries 5
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
maximum sessions 2
shutdown
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 4
Chris
Hi Chris,
No problem, glad I could help.
SCCP configuration gets a little easier after you do it a few dozen times. Barely.
Sneaky hint: there's a SCCP auto-config similar to MGCP. But, it's only for SCCP controlled FXS ports. If you start banging your head against the wall, you can configure an FXS port, and then copy the configuration.
SCCP autoconfig only requires this config:
sccp local
ccm config server 1.1.1.1
ccm config
ccm sccp
(And then you chop off the last 9 digits of your local bound MAC, and configure a FXS port in CUCM)
-nick
Hall of Fame Super Red
Hi Nick,
Great work my friend! That was some keen troubleshooting. +5 points for this and for all your excellent work here lately :)
Cheers!
Rob
Which Version is te IOS required to register the Router 2811 to the CCM 7.1(5) using SCCP??
Regards.
Richard
Bronze
I would go with at least 124-24.T2.bin or later?
E.g. config may look something like:
sccp local FastEthernet0/1
sccp ccm 10.1.3.12 identifier 2 version 7.0
sccp ccm 10.1.3.11 identifier 1 version 7.0
sccp
sccp ccm group 103
bind interface FastEthernet0/1
associate ccm 2 priority 1
associate ccm 1 priority 2
associate profile 10 register XCODEGW
associate profile 20 register CONFGW
codec g711ulaw
codec g729r8
codec g729ar8
codec g729abr8
codec g722-64
codec ilbc
codec g711alaw
maximum sessions 6
description **HW ConferenceBridge< codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
codec g722-64
codec ilbc
shutdown
Which Version is te IOS required to register the Router 2801 to the CCM 8.5 using SCCP with 256 RAM and 127 Flash.
Thank you.
Regards.
Yesenia
Hall of Fame Super Silver
I'd recommand 15.1M or 15.1T train.
Chris
3299
