IOS Dial Peer + CUCM SIP trunk question
Paul McGurn
Level 6
Level 6
We're getting ready to roll out a hybrid solution where we have a handful of CUCM MGCP-controlled IOS gateways that have PRI's connected but will also act as a SIP demerk from our SIP carrier.  I noticed that in order to take this approach, we needed dial peers on the gateways themselves, and also translation patterns in CUCM (the dial peers use the session target command to point the calls to CUCM).
My quesiton, is around making this configuration as efficent as possible.  The we're doing the routing via the destination pattern command, and we do not have much flexibility on the DID of the numbers coming in.  The one attribute to these calls that makes tham all unique vs. our other PRI traffic is that they are all E.164 formatted.  My question is, is it safe/a good best practice to wildcard the destination pattern so that it matches any and all E.164 formatted strings.
Like:
destination-patter +.+$
where the first + is the leading + in the E.164 string, and ".+" is any umber of digits after it (since our PRI's don't pass in anything but the 10-digit DID, no +).
Insight greatly appreciated.
Chris Deren
Yes, since there is nothing else that would overlaps unless you are sending calls out to the SIP trunk with + sign, this is accaptable and will work fine.  On CUCM side you can set the significantDigits on the SIP trunk to 10 digits to strip +1 or use a translation pattern.
HTH,
Chris
Chris Deren
HTH,
Chris
Thanks for affirming.  Yeah, we noted with the carrier that we won't be passing them E.164 on the outbound calls, so we're OK there.  I tested it successfully, so I'm a happy camper.  Managing two dial-peers (CUCM redundancy) for each DID/DDI coming in looked to be an utter nightmare.
