Community Member
IOS dial-peer question
I'm trying to create a voice dial-peer where I can dial 7 digits but only have 4 of the digits forwarded to the appropriate GK.
example:
dial-peer voice 1234 voip
session target ipv4:myGKipAddress
codec g711ulaw
destination-pattern:555....
In destination-pattern I want to discard 555 before send it to GK and send rest of the digits.
-Fred
1 ACCEPTED SOLUTION
VIP Purple
Re: IOS dial-peer question
Fred,
You could use a voice translation rule to accomplish this such as:
voice translation-rule 1
rule 1 /555(....\)/ /\1/
voice translation-profile 1
translate called 1
codec g711ulaw
translation-profile outgoing 1
Hope this helps.
Brandon
VIP Purple
Fred,
translate called 1
codec g711ulaw
Hope this helps.
Brandon
... and you should replace
by
session target ras
Cheers,
Martin
248
