Hall of Fame Super Gold
IOS does not NAT RTP from router itself
I had meet this problem already and here it is again with a new installation.
CME has public IP and ITSP SIP trunk. For this to work,  SIP bind must not be configured, all works fine and there is two way voice with ITSP SIP trunk.
Problem is, customer also wants to use SIP client over IPsec VPN. For this to work, "sip bind all"  must be configured with a LAN interface, otherwise router will source SIP packet with WAN address, making it fail.
What happens, is that once "sip bind all" is configured, RTP connections to ITSP will have the LAN as source, as if the NAT process is entirely skipped.for RTP packets That causes one way voice.
I had resolved this adding a VPN gateway router front end to CME, doing that all works fine.
Does anybody has an indea for have both SIP VPN clients, and SIP trunk work simultaneously with a same router ?
339
