IOS enhanced software MTP
It says you can create a software MTP on The voice gateway. I have looked everywhere for the required config on the 2800 Gateway, but no joy.
I have seen plenty of examples to configure the MTP on callmanager.
I am wondering what commands are needed on the Gateway itself.
any ideas
1 ACCEPTED SOLUTION
Re: IOS enhanced software MTP
Configuring a DSP Farm Profile
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/interop/intcnf2.html#wp1030623
Look at step 9
java
if this helps, please rate
java
www.cisco.com/go/pdi
1 REPLY
Look at step 9
java
java
1058
