09-29-2009 07:21 AM - edited 03-18-2019 10:38 AM
If i have an incoming call from the US into a router's h323 gateway in a certain country and I need to add on 00 to the calling display, how do I go about doing it with voice translation rules ?
For the sake of discussion, say a call from the US ,+12123945XXX goes into the gateway and the called party is 85224023XXX.
How do I go about displaying the calling party as +0012123945XXX , which is adding the 2 '00' to the calling party.
I need to do this using IOS voice translation rules.
Appreciate your help.
Paul
Solved! Go to Solution.
09-29-2009 07:41 AM
Hi Paul,
If it's only for certain international numbers, you can match on the ISDN plan/type. Do a 'debug isdn q931' to see the type and plan and use something like this:
voice translation-rule 1
rule 1 // /00/ type international international
voice translation-profile 1
translate calling 1
That would translate only the calling number for international calls.
-nick
09-29-2009 12:13 PM
Yes, if you want to do it for certain patterns. Check Nick's example for more generic.
+5 Nick from me.
09-29-2009 07:31 AM
What about:
rule 1 /^1233945/ /001233945/
and add translation to correct dial-peer then match calling party number.
09-29-2009 07:52 AM
Hi Konrad ,
Is this how I should do it ?
translate calling 1
dial peer voice 1 voip
dest-pattern 2404.....
translation profile outgoing 1
session target ipv4:x.x.x.x
Thanks and regards.
09-29-2009 12:13 PM
+5 Nick from me.
09-29-2009 07:41 AM
Hi Paul,
translate calling 1
-nick
09-29-2009 05:31 PM
Hi Nick,
I got it to work but I could not using the translation profile on the dial-peer.
I placed the translation profile on the voice-port x/x/x
translation profile incoming xxx
and that worked.
Do you know why it did not work on the dial-peer ? I tried incoming and outgoing on the dial-peer.
Thanks again,
Paul
09-30-2009 05:23 AM
Hi Paul,
Depending on the call flow, you may need it on the voice port. Certain FXS calls flows work slightly different in terms of translation. Otherwise - you may have used different dial peers than you expected.
hth,
nick
