04-08-2008 10:55 AM - edited 03-15-2019 09:56 AM
i am running a stack swith with 3750
here is the show version
i need ip multicast routing with sparse dense mode what ios image do i need?
Cisco IOS Software, C3750 Software (C3750-IPBASEK9-M), Version 12.2(44)SE, RELEA
SE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Sat 05-Jan-08 00:29 by weiliu
Image text-base: 0x00003000, data-base: 0x01440000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(25r)SE1, RELEASE SOFTWAR
E (fc)
Switch uptime is 1 day, 12 hours, 16 minutes
System image file is "flash:c3750-ipbasek9-mz.122-44.SE/c3750-ipbasek9-mz.122-44
.SE.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
cisco WS-C3750G-24PS (PowerPC405) processor (revision D0) with 118784K/12280K by
tes of memory.
Processor board ID FOC1026Y0BJ
Last reset from power-on
4 Virtual Ethernet interfaces
48 FastEthernet interfaces
88 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:0A:B8:3D:11:00
Motherboard assembly number : 73-9357-08
Power supply part number : 341-0108-03
Motherboard serial number : FOC10253U7E
Power supply serial number : DCA10231H3K
Model revision number : D0
Motherboard revision number : A0
Model number : WS-C3750G-24PS-S
System serial number : FOC1026Y0BJ
SFP Module assembly part number : 73-7757-03
SFP Module revision Number : A0
SFP Module serial number : CAT10201JXP
Top Assembly Part Number : 800-25429-03
Top Assembly Revision Number : A0
Version ID : V03
CLEI Code Number : CNMWL10ARA
Hardware Board Revision Number : 0x05
04-08-2008 11:02 AM
The advanced image, the only other available.
04-08-2008 11:04 AM
if i bought the standard image and i tried to download the advance it did let me
why>
04-08-2008 11:17 AM
Hi, we like to discuss mainly on technical issues here.
What you can download and can or cannot legally use, it's your responsibility only. Once upon a time, it was called honor system.
You will find however that cisco's stance to protecting licensing is changing, and the latest generation switches (xxx-E)are an example.
04-08-2008 11:18 AM
so can i buy the right to get this switch to enhanced mode?
04-08-2008 12:54 PM
Yes. Your cisco reseller should be able to order the upgrade license for you.
