08-03-2012 01:10 AM - edited 03-16-2019 12:31 PM
Hi All,
Need you help in choosing ios image for router 3825 support outbound call from sip trunk. Our team is not able to configure Router 3825 router with current image( c3825-advipservicesk9-mz.150-1.M7) for outbound call.
We need to enable bind command under dial peer. ie bind command to be work under voice service voip sip parameter
Pls sugges the IOS
Thanks, nihit
08-03-2012 02:59 AM
dial-peer level bind CLI for SIP signaling and media is available in 15.1(2)T and above. Select any latest IOS image.
Ronak Patel
Rate helpful posts.
08-03-2012 09:32 AM
hi Ronak,
Thnx for revert, Can you let me know whether it IoS should be of enterprise edition or else.
08-03-2012 09:59 AM
You can use the feature navigator to find the correctly IOS to supply your needs.
cisco.com/go/fn
Rate this if helps you
Leonardo Santana
08-03-2012 10:45 AM
I have been having very good luck with 15.1.4M train, download the latest from this train or 15.1T and you should be OK.
HTH,
Chris
