IoS suggestion request
Hi All,
Need you help in choosing ios image for router 3825 support outbound call from sip trunk.  Our team is not able to configure  Router 3825 router with current image( c3825-advipservicesk9-mz.150-1.M7) for outbound call.
We need  to enable bind command under dial peer.  ie bind command to be work under voice service voip sip parameter
Pls sugges the IOS
Thanks, nihit
Everyone's tags (3)
Blue
dial-peer level bind CLI for SIP signaling and media is available in 15.1(2)T and above. Select any latest IOS image.
Ronak Patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
hi Ronak,
Thnx for revert, Can you let me know whether it IoS should be of enterprise edition or else.
You can use the feature navigator to find the correctly IOS to supply your needs.
cisco.com/go/fn
Rate this if helps you
Leonardo Santana
Hall of Fame Super Silver
I have been having very good luck with 15.1.4M train, download the latest from this train or 15.1T and you should be OK.
HTH,
Chris
244
