ā12-18-2013 03:52 AM - edited ā03-16-2019 08:55 PM
Hi All,
We just planed to use the TCL IVR Script for AA. Before put in to the production we would like to know about any limitation / Restriction on the no of concurrent session handled by TCL or Route Memory usage .
I could n't able to find the Cisco document for same. Kindly clarify
Thanks in Advance...
ā12-18-2013 04:32 AM
A maximum of ten call queues and ephone hunt groups can be used with the call-queue script.
An AA can use a maximum of three hunt groups from those ten, but an AA can also use fewer than three hunt
groups or several AAs can share one or more hunt groups. A shared operator hunt group is not included in that maximum; you can add a shared operator hunt group in addition to the three hunt groups that an AA uses, or it can be part of the three hunt groups. The maximum number of calls that can be in queue for each of the ten possible hunt groups is 30, so a potential of 300 calls can be queued..
Here is the document you can read for more details:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/bacd/configuration/guide/40tcl.pdf
Br,
Nadeem
Please rate all useful post.
ā12-18-2013 04:35 AM
Hi Nadeem
Thanks for the reply. We need the clarity on the limitation on resource usage ( CPU & memory ) in Voice Gateway.
Please help on this..
