ios translation profile help
Hi all, just wondering if someone could review my translation the goal is to make outbound caller ID for local as a 10 digit number and LD as a 11 digit number... thoughts? main number being 8015555555 example
voice translation-rule 1
rule 1 /^9/ /8015555555
voice translation-rule 2
rule 2/^91/ /18015555555
voice translation-profile outboundIDlocal
translate called 1
voice translation-profile outboundIDLD
translate called 2
dial-peer voice 1 pots
destination-pattern 9[2-9]......
port 0/0/0:23
translation-profile outgoing outboundIDlocal
dial-peer voice 2 pots
destination-pattern 91[2-9].........
port 0/0/0:23
translation-profile outgoing outboundIDLD
1 ACCEPTED SOLUTION
Re: ios translation profile help
Hi rywalker
I am not sure how many Digits you are using on IP Phones however if you have phone extensions like "5555" and "5556" and wants to change the Calling number only then the following should be the correct translation rules to achieve what you want:-
rule 1 /^555\(.\)/ /801555555\1/
rule 2 /^555\(.\)/ /1801555555\1/
For Single number "5555", following should work:-
rule 1 /^5555/ /8015555555/
rule 2 /^5555/ /18015555555/
translate calling 1
translate calling 2
port 0/0/0:23
port 0/0/0:23
-HTH
- Basant
sorry I think its supposed to be
translate calling
Try the IOS command "test voice translation-rule 2 "
This way you can review what's happening.
Cheers,
Martin
Hi rywalker
translate calling 1
translate calling 2
port 0/0/0:23
port 0/0/0:23
-HTH
- Basant
273
