Community Member
IOS Upgrade - Unity Express
Hi Netpros.
I've just done a IOS 12.3 - 12.4 upgrade on my 2821 which had a NM-CUE module installed. I rebooted the router and have lost all the config for the CUE? I also can't seem to enable the servier engine module as the command isnt there ?
I'm runing SP Services 12.4.25 - has anyone got any idea whats happened?
Rod
1 REPLY
Re: IOS Upgrade - Unity Express
Hi Rod,
Can you provide a show tech from the 2821 please? Are you saying that you are unable to access voicemail or you are simply unable to session into the CUE? Can you capture the command you are using to session into the CUE when you collect the show tech?
Harmit.
-- Regards, Harmit.
138
