IOS Version for WIC/VIC Card in Cisco 2801 Router
Hii all,
Greetings!!!
I have a query
We are having a Cisco router 2801 with one Adsl card ,one T1/E1, & one VIC card with 2 FXO ports
WIC/VIC Slot 2:
        FXO Voice daughter card (2 port)
        WIC module not supported/disabled in this slot
        Hardware revision 1.1           Board revision J0
        Serial number     24283772      Part number    800-02495-01
        FRU Part Number   VIC-2FXO=
        Test history      0x0           RMA number     00-00-00
        Connector type    Wan Module
        EEPROM format version 1
        EEPROM contents (hex):
          0x20: 01 0D 01 01 01 72 8A 7C 50 09 BF 01 00 00 00 00
          0x30: 98 00 00 00 01 01 31 01 FF FF FF FF FF FF FF FF
My query is
1.Which IOS ver should i run in my router which supports VIC card ?
Am having a cisco 2801 router with 128MB/64MB mem
Currently am using IOS ver "c2801-spservicesk9-mz.124-3g.bin" but its not supporting my VIC card.
Awaiting ur prompt response.
Thankyou in advance for ur understanding and cooperation.
Brgds,
Arif.
2 ACCEPTED SOLUTIONS
Hall of Fame Super Gold
Re: IOS Version for WIC/VIC Card in Cisco 2801 Router
That old card is not support in 28xx routers, no matter IOS used.
You must use VIC2-xFXO card.
Super Bronze
1) First problem is that VIC-2FXO isn't supported on the 2800 platforms - you need a VIC2-2FXO.
2) Secondly, you will need DSPs on your 2800 motherboard - these woudl appear in your hardware list on the router as PVDM2-xx
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Thanks alot for ur reply.It really helped me alot
Can u tell exactly which VIC card supports 2801 with128/64Mb mem?
Appreciate ur prompt reponse.
Super Bronze
Aaron
Thanks for ur reply.
can u plz tell me what r da exact o/p commands to check pvdm & dsp on router(ASAP)?
Thanks in advance.
Super Bronze
Show diag
Post the output if you don't understand it, but it's quite clear - basically if you have PVDMs you will see parts like PVDM2-32 for example
The last number (32) indicates the number of DSP channels - for a 2 port VIC, you require at least 2 channels for G711 calls. If you are running G729 or other codecs you would need more. I think the smallest is a PVDM2-8.
Aaron
Thankyou soo much for ur reply.
Can u plz post a sample ASDL configs on 2801 router with one ATM interface(ASAP)
Awaiting ur quick response.
982
