%IP-3-LOOPPAK: Looping packet detected and dropped -
Hello All,
Recenlty we have upgraded the IOS from c2800nm-ipvoicek9-mz.124-15.T14.bin to c2800nm-ipvoicek9-mz.151-4.M8.bin. After that the gateways are hitting the below error message. The src IP is voice gateway IP address and dst IP is muliticast MOH IP configured under call manager fall back. Assistance are much appreciated..
src=10.0.XXX.XXX, dst=239.X.XXX.254, hl=20, tl=116, prot=17, sport=16803, dport=16385
in=local, nexthop=239.X.XXX.254, out=GigabitEthernet0/0
options=none -Process= "VOIP_RTCP", ipl= 0, pid= 299
-Traceback= 425C9758z 425CAA30z 425CBBFCz 425CC0D4z 425CD214z 425CD524z 425CD590z 42AC4178z 43AA20DCz 43AA9B44z 437F3094z 437F3078z
Murali
CSCtn83520 is a suspect but
CSCtn83520 is a suspect but you are already on an IOS version that contains the fix to this defect.
Are you facing any issues with calls or MOH?
Can you attach your show run
Can you attach your show run here so we can take a look?
548
