Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
IP address in SRST
I'm using call manager 8.6 in central location .all branch location phones are using central location DHCP servicer for IP address and register with central location call manager. during WAN outage branch location phones will fall in SRST mode.
I have small doubt.
when branch location phones fall in SRST mofe phones will retain the same IP address or it requires local DHCP server for IP address.
please clarrify,
Re: IP address in SRST
Hi.
IP phones will have the same ip address and they will use the SRST reference previously onfigured on CUCM to Fallback.
Carlo
Please rate all helpful posts "The more you help the more you learn"
IP address in SRST
The phones will retain their IP addresses.
Yosh
HTH Regards, Yosh
Hall of Fame Super Silver
The previous answers are correct, in addition the phone will lose their IP half way through the dhcp lease cycle, so if they remain under SRST too long and lease time is short they will lose IP and unregistered.
Chris
IP address in SRST
Correct Chris +5
That's why SRND suggests two options:
1) configure a DHCP Lease time at least 8 days long
2) Provide a local DHCP service so that IP Phones can go on conmmunicating with their DHCP server
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/9x/netstruc.html#wp1184975
Carlo
IP address in SRST
Good stuff (+5)
Yosh
HTH Regards, Yosh
135
