IP address of phones will not update when moving to a new subnet
We have several buildings and each building has a separate voice VLAN. When we move a phone from one building to another, it will not update with a new IP address. I don't think it's a DHCP problem, new phones register just fine. I can even take a new phone put that MAC in Callmanager on the old profile and the new phone will work correctly for the number.
I have tried a hard reset on the phones (this is happening to various models 7911, 7941G-GE, 7941G, 7961G-GE). The phones show they are updating, then go back to their original IP which will not work in the building they've been moved to.
When the phone is in this state I can't access the settings to change it to a static IP but if I take the phone back to the building it is from it will work just fine and I can access the settings button there.
I don't believe it's a VLAN problem, since the other phones all work just fine and new ones will register without an issue.
Our deployment is fairly new so I don't actually recall if we have moved any phones successfully previously.
Thanks for any help.
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: IP address of phones will not update when moving to a new su
Hi Teresa,
It almost surely is a problem with the DHCP server. We were experiencing these exact issues and spent many hours trying to troubleshoot them to no avail. The symptoms sound identical.
Rob
Hi Teresa,
We ran into this exact problem recently when planning in our lab for a Network re-design. DHCP Scopes and IP Helper addresses were all set properly and yet nothing worked when moving an existing phone from one subnet to another :( New phones were just fine and could register no problem. This turned out to be a problem (probably a bug) with the "built-in" Windows 2000 DHCP server in CCM and when built a Windows 2003 DHCP server with the same information everything started working perfectly. IP Phones can move between subnets without any intervention, just like it should be!
Hope this helps!
Rob
Please remember to rate helpful posts....
We are actually using an external DHCP server, so we aren't using the one in CCM. It is an older Windows server however, so maybe it's an older DHCP server problem.
Thanks much for the input.
Hi Teresa,
Rob
Thank you, thank you! You gave me the clue I needed. I went into the Address leases on the DHCP server and deleted the one associated with the phones that wouldn't re-register. When reset, they came up just fine!
Hi Teresa,
Great work on this! It is always good to fix something up b4 the weekend :)
Enjoy! And best of luck.
Rob
PS: With a little more tweaking you won't have to touch anything when you move the phones...
116
