07-07-2008 03:38 PM - edited 03-15-2019 11:47 AM
Hi all,
I cannot complete a conference call. In fact, the screen says "can not complete conference"
Any ideas?
Randall
07-07-2008 04:12 PM
CUCM? CME? version?
only happens with CIPC?
internal phone? PSTN phone?
SW or HW CFB?
G711 or G729?
javalenc
if this helps, please rate
07-07-2008 04:25 PM
It turns out the problem is, codec negotiation.
In IPC, configuring the "optimize for low bandwidth" causes codec issues. Since this was local calls there was an issue.
Randall
07-07-2008 04:27 PM
that option would cause the call to be established with G729 so if you're using SW CFB that would fail due to the fact it can only handle G711
javalenc
07-07-2008 04:29 PM
correct. Once I changed it... it worked.
Thanks for your help on this and in the past.
Randall
07-07-2008 04:44 PM
you're very welcome Randall =)
javalenc
