IP Communicator 2.0 error
Hi all,
I cannot complete a conference call. In fact, the screen says "can not complete conference"
Any ideas?
Randall
Re: IP Communicator 2.0 error
CUCM? CME? version?
only happens with CIPC?
internal phone? PSTN phone?
SW or HW CFB?
G711 or G729?
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
It turns out the problem is, codec negotiation.
In IPC, configuring the "optimize for low bandwidth" causes codec issues. Since this was local calls there was an issue.
Randall
that option would cause the call to be established with G729 so if you're using SW CFB that would fail due to the fact it can only handle G711
javalenc
java
correct. Once I changed it... it worked.
Thanks for your help on this and in the past.
Randall
you're very welcome Randall =)
javalenc
java
303
