IP Communicator 2.1.3
How to disable the Web access, please provide the steps for the same...
Web access enable option cannot be changed to No on the security configuration.
appriciating for quicker response...
Re: IP Communicator 2.1.3
set up ACL blocking 80 using either the IP of the communicator or the CCM as the host.
I am trying to access an application which is installed on my local PC with the following URL http://localhost, when the ip communicator is on it takes me to the Device configuration screen insted of the application, if i block the port 80 will i be able to access the application.
Thanks...
you could always configure your app to listen on a different port http://localhost:8080 perhaps?
is there any posibilty for the ip communicator to listen to a different port since i cannot change the port for the application.
CIPC interferes and conflicts with the web server installed on the PC
http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K54967101
You can only disable it but there is no way to have it listen to other port
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
113
