IP Communicator administration tool
Anybody knows about IP Communicator administration tool? Please let me know the link to know about it.
Re: IP Communicator administration tool
it's in the same zip file where you get the IPC
CiscoIPCommunicatorAdminToolSetup.exe
java
if this helps, please rate
java
www.cisco.com/go/pdi
Thanks. I need to know the purpose and functionality of this tool. Can you please provide any guide for it?
guess you have not downloaded and looked at any file because info is on the README.TXT
- To be launched on the TFTP server or Cisco Unified Communications
Manager Publisher. This tool will install the DirectoryWizard tool
for configuring the Quick Search and Dialing Rules features. It also
enables HTTP access for AutoUpdate and for IP Address auto-detection
in the network audio settings for unsupported VPN clients (getIP.asp).
refer to README.txt for any other info
java
java
Yes. I got the same information from cisco site.
426
