Community Member
IP Communicator : cannot use extension mobility
I cannot use the extension mobility with my ipcommunicator.
Done :
enabled Extension mobility
created Phones Services,
Created profiles with directory number
created users associated with profiles
When i use the button "service" of the ipcommunicator, it display :
To set the numbering abstract and other services for your phone, go to https://W.X.Y.Z/ccmuser/showHome.do
and when i'm going to this page there is nothing.
With an IPPhone it is OK.
How can I do? Have you any issues?
Best regards.
Silver
Re: IP Communicator : cannot use extension mobility
Please confirm that if you login to IP Communicator EM. Try restarting Cisco extension mobility and Cisco extended functions or activate Cisco extended function service.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/4_1_3/ccmfeat/fsem.html
Or please check if following Enterprise Parameters value contains IP Address instead of host name.
- URL Authentication
- URL Directories
- URL Information
- URL Services
If not, please rename into .
Go to CCM Administration page > Service > Service Parameters, then
* Server - choose a server on which TFTP service running
* Service - Cisco TFTP
In the next page, click 'Advanced' button.
Set 'False' to the following parameters;
Enable Caching of Constant and Bin Files at Startup
Enable Caching of Configuration Files
http://www/en/US/docs/voice_ip_comm/cucm/admin/4_0_1/ccmcfg/b05phsrv.html
u did subscribed the IPC to the EM service right?
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
220
