IP Communicator/CIPC compatible handsets?
I've found the list of tested audio devices for use with Cisco CIPC, but am looking for a handset (ie Jabber handset 450 for Cisco) that would be compatible.
Any suggestions for devices?
Many thanks.
Hi, Jabber handset supports
Jabber handset supports CIPC(Cisco ip communicator) but you have to check the version of your CIPC.According to the
the jabber vendor i.e Jabra
SUPPORTED CISCO PLATFORMS
Jabra audio devices offer on-device call control and integrate seamlessly with all Cisco Communication platforms
including:
- Cisco IP phones and Cisco Cius
- Cisco Mobile Solution
- Cisco Jabber, CIPC, CUPC
- Cisco WebEx Connect
- CUCILync
- Cisco Movi Clients
http://www.jabra.in/business-solutions/for-your-platform/cisco
http://www.jabra.in/products/accessories/jabra_handset_450_for_cisco_series/handset_450_for_cisco_dark#specifications
and according to cisco doc
Handset
Vendor Handset                                 Jabber for Windows
Jabra Jabra Handset 450 for Cisco    Yes
Jabra Jabra Dial 550                           Yes
http://www.cisco.com/c/en/us/products/unified-communications/uc_endpoints_accessories.html
You can also check Cisco IP Communicator Guidance for Headsets and Handsets
http://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/ip-communicator/prod_bulletin0900aecd800f4564.html
Aateek Singh
Network Engineer
Spooster IT Services
Re: Hi, Jabber handset supports
Is it supported with Cisco Jabber for Mac? I do see and select the handset as the main speaker and mic for Cisco Jabber but it is not working! Btw I'm using Jabra 450 handset.
Naoufal
271
