Community Member
IP Communicator Client
Is there a IP Communicator Client for the Apple I-Phone and the Blackberry 8330 ? If so where can you get it?
1 REPLY
Re: IP Communicator Client
No, IPC is only for Window based computers.
You can try any SIP client you can load onto the devices and use them as 3rd party SIP phones.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
137
