IP Communicator - Conf Call Set Up
Can some one recommend the equipment needed if you have an IP Communicator as your telephone. I will assume you need two NIC cards for this to happen.
Re: IP Communicator - Conf Call Set Up
IPC, call control agent and a CFB (SW/HW) not sure why you mention you need 2 NICs. what for?
IPC is just the same as a 7970 but in your PC, it's the same thing to make a conference there
java
if this helps, please rate
java
www.cisco.com/go/pdi
You do need to allow traffic from the Data VLAN to access the Voice VLAN and vice versa. That or a 802.1Q aware NIC/second NIC.
We are using IP Communicator 7.0.1.0 and I am using a wireless headset. I have some one else who would like to use a wireless headset and use the IP Communicator for conf calls in his office, so this is why I ask about what equipment or changes need to be made in order for this to work.
Hall of Fame Super Silver
As long as the PC that IPC is installed on can talk to CallManager servers you do not need anything extra.
Simply configure IPC on CM and point IPC to the correct tftp server and off you go.
HTH,
Chris
279
