Silver
IP Communicator + EM + "Use this device name"
I'm trying to get IP Communicator and Extension Mobility to work with a user defined device name. Unfortunately, no go. When I try to login, I get "Login Unsuccessful" and an Error [11] on the status line of the phone. When I look at the trace files, I get:
7: Jan 11 16:06:07.454 EST %EM-3-UNK:0: LoginService: Dev: SEP000CF1CD12CD- Error #11 - Policy Violation: Device does not exist: Device does not exist
Where SEP000CF1CD12CD is the original name of the device/NIC.
What gives? Anyone had this problem?
Re: IP Communicator + EM + "Use this device name"
correct link for configuring the extention mobility is http://:8080/emapp/EMAppServlet?device=#DEVICENAME#
Silver
There is a bug in IP Communicator where if you use the service URL button, it injects the MAC address of the device without looking at the user defined device name.
CSCsh60628: IPC 2.0 EM SURL button does not work with a custom devicename (MAC)
I have followed all the steps to configure extention mobility but when I try to login appear a message that say "incorrect login error 207 device name".
How I can solve it ?
Gustavo
Silver
Hi Gustavo,
Here is a list of all the current error codes for EM:
200
NO_ERROR-Successful.
201
Authentication error
AUTHENTICATION_ERROR-Authentication failed for user. Shows the user login page with error title.
202
Blank UserID or PIN
NULL_PARAM-Shows the user login page with error title.
203
Application UserID/Pwd null
APP_AUTHENTICATION_ERROR-Unable to find registry entry for AppUserID/Password.
204
Directory server error
DIR_SERV_ERROR-Exception occurred while performing diraccess.authenticateuserwithpin().
205
User Profile absent or null
DEV_PROF_ERROR-User profile absent or null.
206
No Device Profile associated with User
DEV_PROF_UNAVAILABLE-No Device profile associated with user.
207
Device name empty or absent
NULL_DEV_ERROR-Device name empty or absent.
208
Cannot connect to EM Service
LOGIN_SERVICE_CONN_ERROR-Unable to connect with EMService.
It sounds as though you need to create device profile in CallManager. Have you done this?
Basically, once this is done you can associate this with the end user account which you are using to log on with.
Basic steps are these:
1) Create device profile with dir number
2) add em service to profile
3) Create end user account and add device profile to it
Please rate useful posts..
1182
