Community Member
IP communicator for Iphone or NOKIA n97
Dear all,
If there is IP communicator client installed for Iphone sets or NOKIA n97 to act as ip communicator on the PC to be used anywhere outside the company.
Note, i use CCM version 4.23
Re: IP communicator for Iphone or NOKIA n97
No, there isn't. However you can use any SIP client, but your version doesn't support SIP phones.
You might want to look into CUMA and CUCM for the functionality you're looking for.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Community Member
Thx for yr reply.
What is the latest version for CCM now?
7.1 is the latest release and is very stable.
Version 8 is scheduled for release in Q1 2010.
509
