I'm using a Plantronics Blackwire C620-M headset with IP Communicator 7.0.4.0. When I press the mute button on the headset, it toggles mute on IP Communicator only every other time. However, the headset microphone is muted every time. Therefore if I press the headset button to mute the microphone, I have to press it 3 more times to unmute everything:
Action | Result |
Press mute button on headset | Headset and IPC both muted |
Press mute button on headset again | Headset unmuted; IPC still muted |
Press mute button on headset third time | Headset muted; IPC unmuted |
Press mute button on headset fourth time | Headset and IPC both unmuted |
Any ideas on how to sync the headset and IPC mute functions?
