IP Communicator & headset mute button out of sync
I'm using a Plantronics Blackwire C620-M headset with IP Communicator 7.0.4.0. When I press the mute button on the headset, it toggles mute on IP Communicator only every other time. However, the headset microphone is muted every time. Therefore if I press the headset button to mute the microphone, I have to press it 3 more times to unmute everything:
ActionResult
Press mute button on headsetHeadset and IPC both muted
Press mute button on headset againHeadset unmuted; IPC still muted
Press mute button on headset third timeHeadset muted; IPC unmuted
Press mute button on headset fourth timeHeadset and IPC both unmuted
Any ideas on how to sync the headset and IPC mute functions?
Everyone's tags (3)
705
