Community Member
IP Communicator Locale problem
Hi There !
I'm having a problem with locales in the CUCM7.1.3 (just upgraded from CM4.x).
I try to change the locale of the CIPC but it does not seem to recognize the change, and the softkeys stays in the same language.Only the right-click menu changes the language...
This is causing me a problem because some remote users are trying to download the locale, and if I configure it to use the default locale, it doesnt work... and the download restarts everytime the CIPC is opened..
Thanks for any help.
Andrei.
Community Member
Re: IP Communicator Locale problem
Andrei
Did you can solve your problem? I'm with same problem after upgrade 4.x to 7.x
Community Member
It is a bug
CSCee83101
Community Member
Hi !
You have to upgrade de IPCommunicator version.
7.1.3 if I'm not mistaken
Andrei.
407
