Community Member
IP Communicator on 64-bit OS
I know Cisco don't support IPC on a 64-bit OS but does anyone know of a version that will work for a lab?
Cheers
Rich
1 REPLY
Re: IP Communicator on 64-bit OS
I'm running IP Communicator version 2.1.3 on Vista Ultimate x64 with no issues. Laptop is a HP dv9580us.
Task manager shows communicator.exe*32
I also run it on a XP image under MS Virtual PC 2007 (free) on a old HP nc6000 laptop. The audio stutters but that laptop is ram and cpu deficent. Works fine for testing purposes.
852
